skipper by palomar
halfcent
Sep 13, 2009
8
70
i ran across this amp and have no idea what it is as far as input wattage and output wattage.it is a mobile,with a blue face.it has it has power,preamp and am-fm cw ssb switches with a rotary knob for low,med,high and max.does anyone know?
Are you talking about one like this ?
This one is a 4 pill 4x454's nice clean little amp.
they were damn decent amps as long as you were willing to use them the way they were intended to be used
There have been several versions, but the one with Motorola 454 transistors should be good for about 350/400 watts on SSB and stay reasonably clean.
They had regulated biasing that actually worked decent, they make a good little mobile 10/12 meter amp
Some of the later ones had 2879`s in them as well.
Not bad little amps.
