SMART 10Meter Amateur Mobile Radio
Stumblefoot
Jul 12, 2022
8
10
13
68
I can't find any info on this radio, it's very small Its AM/FM Frequency range 25.615-30.05MHz 6 bands. Output is 8 Watts or 4 Watts FM/AM according to the manual. I got it used, plugged it in, nothing..replaced fuse still nothing. seems like it would be a good little radio but not sure if its worth repairing.
  • Haha
Reactions: Rwb
Anytone Smart. Probably this one https://manuals.plus/anytone/smt02-smart-10-meter-ham-radio-manual . Pretty much useless for ham as it lacks repeater offset or CTCSS/DCS but it should have 5khz tuning. It should have a diode near where the power goes into the board to save the board in the event power is hooked up backwards. Bypass it with a jumper and see if it cuts on you may be lucky, or it might either not have such a thing or be tiny SMT
i owned 1 and it lasted almost as long as warrenty,they sent me a replacement n i swapped it off never turning it. on cheep too
Thanks, but its not an Anytone, hence my bewilderment, it has NO markings on the case or mic no serial # nothing. The Amytone Smart doesn't have these frequencies built in. nor the output power this one claims, and has its logo on the top and the mic.
I'll open it up later this afternoon and look for that diode
And I hadn't really planed as using as a Ham but band DE is the CB band...26.0965-27.405
  • Haha
Reactions: Rwb
its an anytone. they had like 9 bands desolder a place n gave our 40 channels and upped it to a lip burning 8 watts
The smart 10 you need to resolver the jumper block.. To get the 11 meter band and others.. Power off hold key the mic push the a/f button and power up to choose the band .. Or to change the power output. Power off key the mic push down the rfg button and power up you can choose Pl pm or pH power levels.. There's 2 mods also 1 for audio and 1.for audio limiter bypass yo can find on you tube there's 2 different boards chose the right one for the mod it's pretty ez
Reactions: Rwb
