I've noticed lately that when I go to a different channel. The signal strength on that channel is different than the channel I was on.
For instance. I was on channel 19 talking to a local and then we switched to channel 27 the signal I was receiving was different. It was lower he sounded farther away. What is causes this problem? The SWR is fine. Flat across the band.
Could it be that the person I'm talking to has a SWR problem of his own and it causing his radio not put out on those frequencies the same? Just found it really strange.
