SSB Stability: Can it be Improved?
Robb
Honorary Member Silent Key
I Support WorldwideDX.com!
Dec 18, 2008
11,418
3,660
323
Silicon Valley CA, Storm Lake IA
I have and use a Galaxy DX99V in my vehicle - daily. It has this terrible habit of not being stable for the first fifteen minutes after it is turned on. I don't live in a cold climate here in CA. Morning and overnight temperatures seldom go below 32F. But even if it is 40F overnight and I turn the radio on, it drifts so much that it is unusable until it warms up. Even 50F makes it a bit squirrelly.
I recently aligned the PLL after unlocking the fine clarifier. The 10.240mhz reference oscillator crystal was reading 10.24032mhz at the PLL chip (pin 4) after I let it thoroughly warmed up on the bench for over an hour.
Is it out of tolerance?
But is it this crystal that is causing the problem? I think not; but I thought I would open up this discussion and get some insights because of other possibilities (before I can begin to remedy this issue). Or is it the thermistor that is faulty? Or perhaps is it the PLL offset oscillator crystal? Or maybe the carrier offset oscillator crystal? Or it is something else that I should look into?
If I must replace a crystal or three; then I have resigned myself to get the job done. Just want to get to the core of the problem and make as stable as is practical w/o missing the problem area. Is there a place that has these crystals on-the-shelf to replace the original part for a better tolerance part - one that stays stable w/o going to a 'Temperature Controlled Xtal Oscillator' ("TCXO")?
My Cobra 148GTL, GrantXL, and Magnums don't share this malady.
Why does Galaxy and Ranger radios suffer so?
http://www.mhelectronics.com/highstability.shtml
Hi Robb, I am not aware of a fix. Many ham rigs have as available options High Stability Crystal Heaters, but not for the exports.
Go out and turn the radio on 15-20 minutes before you leave.
theres more to frequency stability than the crystals,
having the right positive and negative temperature coefficient components in the oscillator to minimise thermal drift is at least as important as the crystal,
heres a cheap easy to fit way to stabilise your crystal, it won't do anything for your oscillator components if the builders got the temp coefficients wrong,
Kuhne electronic*|*QH 40 A
i have seen homebrew heater circuits but they are bulky/ugly:wink:
It's a matter of circuit design and implementation. If you want to go to the trouble you can certainly shorten that 'warm up' time. Can't do away with it entirely, but make it 'better'. It will not be cheap-n-easy (depending on your skills), at least not for me :).
So what's causing all of that 'drifting? Probably all of that you described, along with part placement etc. I'm not familiar with that radio so can't say anything definite.
Those little crystal heaters are sweet and simple to install. Truthfully though I doubt even with the heater you'll solve the issue. I believe it's a combo of parts, design and temp.
I actually talked to a galaxy tech a while back regarding a 959 and he said in not so many words to me - that's just the way it is.
