Stryker 440 driving a 4 pill hi-drive amp(x400hd)
bobster
Nov 15, 2012
4
46
Does anybody know if the stryker 440 will drive the xforce x400hd 4 pill amp descent. the stryker 440 is stock with no mods. If anybody is running the styker 440 with amp please share your words of wisdom. thanks ya'll<can not stand it>
There's a video on youtube of a guy with a Stryker 440 pushing an Xforce Midnight Special 500 which has 4 - 1446 pills and that Stryker drove that amp great! I should drive a Xforce 4 pill the same way.
sent from my Davemade® phone
I think that would be a good match. Enough drive out of the stryker to get down when conditions are rough.
Sent from my iPhone using Tapatalk.
45, North Florida
I run the 440 into a straight 4 pill with 2879's. Hardly creates any heat with 150 DK.
Seeing 500 peak on a radio Shack meter. Amp did 620 with same radio on the bench into a Bird peak meter on channel to,very little harmonics. -45 db
I also run the same radio into a straight 2 pill with same finals and while it works it does get hotter.
The bigger box is just loafing along with a 5 watt radio dk.
