Superstar 3900 help. Early EPT360011B
smalltiredart
194
58
38
Struggling on a problem on this one.
No RX on AM and FM only.
TX is fine on both AM and FM, but No RX. No sound at all. No Meter movement etc. Even with close range radio
RX is fine on LSB and USB but noda on AM/FM
The only 360011B schematic I could find was for the "Galaxy Plus" on CB tricks
Any ideas are appreciated. I can voltage test any of switching transistors, but info on this early board seems scarce.
I have DVOM, Capacitor tester, Oscilloscope, ETC.
Removed and tested all the above diodes. Also Replaced FL1 with a known good filter, still no dice.
Doesn't even budge the S needed and 0 sound on AM and FM.
It hears fine on USB LSB and CW.
Strange one for sure. Transmit is fine so audio chip is fine.
Any other ideas ?
Thanks Rob.
I did check the mode switch as well. With ohm meter and made sure switching voltage under power.
Mode switch?
I had the same problem with this radio once.
Turned out it was one of diodes already listed; not the mode switch. But a mode switch can also be a failure point here.
