Quick question. Can I use it as it is with it on with the low SWR or may I be looking for trouble. Now I'm afraid of a possible fire.Have you tried just connecting the antenna straight to the radio? That will tell you a lot.
If your antenna SWR is below 2:1 it is usable. If you are running power it is still usable.Quick question. Can I use it as it is with it on with the low SWR or may I be looking for trouble. Now I'm afraid of a possible fire.
When you tune the antenna's SWR you are tuning to a FREQUENCY not a power level.
The SWR going into the amp is affected by more than just the antenna. Capacitors can be shorted or opened, inductors can do the same. If it is part of the input circuit of the amplifier impedance can show high SWR.
If you can take the amp out of the circuit and go straight to the radio check your SWR then. If you have an antenna analyzer check it that way.
There are lot of possibilities, If you have installed the system properly and the power wires are fused the likelihood of fire are lessened.
Ok, so I went looking for my barrel connector but its male to male so going to buy one. May take a day or so. I did mention it did not do the same thing on my other antenna but I double checked with 4 antennas just now and all do go up in SWR with the amp off. Some more than the others. Predator showed 3 the others went up to 2ish with it off, from 1.2 matched with the amp on. None did this before. I am guessing that L1 might be the culprit as you explained. I did do some skipshooting the last couple of days and it could have gotten hot. I usually have fans on it but I took them off for new ones I haven't hooked up yet. I guess I'll know when I get the connector. Thanks.
IT may indicate a burned relay contact or coax jumper to rear connector.
Why do I say that?
When you run hot amps - e.g. little to no fan cooling - that coax sleeve and insulator is plastic and will soften.
IT may not perforate - but it will soften and then it tries to find a good equilibrium to rest once the heat is removed - that can make the coaxial aspect of equal distance throughout the length of jumper - in question. You may have a warped coaxial jumper from the heat produced in the amp.
So don't use the amp until you get a better idea of that impedance bump. For when the amp is on, that means the amp itself is absorbing the SWR reflection as in itself. But when the amp is off that relay bypasses the mess but still goes - re-routes - shorts both connectors to themselves - via that relay and the coax itself. So if the SWR issue is in the coax, or even the relay - the Amp is susceptible to self destruct from it, .DON'T USE THE AMP until you figure out your next step and fix it.
Ahh, So is was the one I was thinking about...
Heres a quick tip - KEEP AMP UNPLUGGED FROM POWER - but Reverse the connections - see if the SWR stays the same - Hook up ANT to XMT and XMT to ANT - the recheck SWR - DO NOT POWER THAT AMP DURING THIS TEST.
This is more of a check of which one -
Set SWR on meter to FWD setting...
IF the SWR FWD is the same, then the coax may have been damaged so you simply need to replace jumpers.
IF SWR changes - then more than likely the relay may be more at fault than the coax. Burnt contacts.
The aspects of distance to the connectors is what I'm looking for - if one of the coax jumpers is bad, it's position in the line will affect the FWD reading - not necessarily the overall SWR - it can still be the same - but the ASPECT of the impedance bump affects the CLAIBRATION "FWD" setting too...(Because the coax and the antenna AFTER then look as a complex load affecting the impedance bump like a coaxial balun)
Just some thoughts...
Not sure this was the problem, cause, or what totally. I rewired the connector and its still the same only now the SWR dropped a little from 3 to 2 with it off and with it on it now drops lower to 1:1. The normal SWR for the antenna I used Skipshooter and predator 5ft was 1.3ish matched on 1 and 40.OK, so I tried hooking the meter where the amp goes. Pretty sure I found the connector may be loose from the connector to the antenna coax. The other jumper I had was new and this one is older. Maybe should have changed both. Going to check the connector now. I can change the swr turning the coax which I know it shouldn't be turning all the way around.
Here is why I'm thinking what I posted above...
The above is a portion of a T/Star Schematic - courtesy of CB Tricks - the Switch Side.
Note S2 - C3 - C44...
Now I had someone a long time ago say, why not check the terminals? Wouldn't the relay short out the antenna to XTMR? Well, yeah, but it is not a dead short - it's a RF short but not a physical DC derived Short.
S2 switch - routes from Relay - thru itself - back to Relay Pin 5 to 8 will be shorted in OFF state. But not the outputs.
So 6 and 9 are in the center - 5 to 8 are on the "coil side" or closer to the center. IT would be little harder to check.
So let's look at layout...without the parts...
The above shows routing Green Relay 5 to 8 from SWITCH 2 RED TO SWITCH 1 Relay 7 and 10 (Power OFF)
So they would be the quickest way to check for DC short, but not bad RF routing (burned contacts or Cap failure)
So it's why I mentioned the SWR FWD trick, to determine if one side of the relay contacts are open it makes the rest of the system appear RF-bound as a mistuned cap.
