tilehead said:Ok, I found some info that tells how to install talkback on a Uniden or Cobra using a 100 ohm 1 watt resistor. (From the PA jack to the EXT speaker jack). Will this work on my old Galaxy? If so could I cut the wires to the Roger beep switch and wire the resistor wires to the to the roger switch? Thanks.
Thank you.Librium said:tilehead said:Ok, I found some info that tells how to install talkback on a Uniden or Cobra using a 100 ohm 1 watt resistor. (From the PA jack to the EXT speaker jack). Will this work on my old Galaxy? If so could I cut the wires to the Roger beep switch and wire the resistor wires to the to the roger switch? Thanks.
No that will not work. You will have to install a talkback board.
