Two ways:what i'm wanting to do, if possible, is to add frequency counter to the face of the grant. can get rid of the switches i never use like pa 19-9 ect.... or if possible put a 148 or even a 200gtl face on it. i know its a lot of work, i know i could just buy a external counter but i would like the clean look.
Two ways:
The easiest way is to find/get a Cobra 148GTL-F used.
It is all there; 100% Cobra 148/Grant XL inside.
The other is to forget about having it modified (useless and costly to be done) as you imagined. Best/easiest way is to add a freq counter to the existing radio and have a interface plug installed on the back. Velcro the counter to either the bottom or top - and Bob's your uncle - most people do it that way and it is by far the easiest, most efficient way to do it. In fact, it increases the value by NOT hacking it up.
I have a really hard time to molest these finer old radios. In fact, I've restored many 148's back to stock - fine as they are.
Snake Radio Customs likes to mod radios the way you've suggested; but then again not too fond of what he does, especially - how he does it, and mostly what he charges to have it done. So he is an option that I cannot really recommend . . .
Two ways:
I just sold an IC-718 for $300. With that amount I did not loose anything.For that kind of money buy a real SSB radio. Get a used HF radio!! Screw $300 just to look at your radio as well. That's just Highway robbery!! Some people are just so fascinated by lights and such they get sucked into the snake radio snake oil!! Like Robb said too much work. Just find a 148GTL-F and be done. These radios are getting harder to find so look around. Prices will vary a bunch so don't be surprised if you see them for 200-300 dollars. For what you'll spend on one, you could add another hundred or 2 and get a used HF radio like a kenwood TS50, Icom 706, and so on. JMHO.
