These are basically the same as a Galaxy 949 without the frills. Capable of channel expansion (very easy), capable of big audio. I have owned several. Problems I see....no place to install an echo board on the face. You have to drill a hole in the case. Do this as an alternative.......Buy one of those little project boxes from radio shack. Mount the box on the side of the radio (perfect size, both height and depth). Mount your echo control, 2 switches (for xtra channels) and you will still have more room to mount a potentiometer or switches for either switchable rogerbeep or a variable talkback (Cant acheive talkback like you do in your cobra 29).
thanks for the info there dirt mover . IM kind of looking for a toy box right now ( a box that I can put about 8 noise toys or so in with push buttons in the front)
TheCBShop over in Syracuse NY coencidently is the inventor of the Peat/Repeat......Also heard that they are doing all the factory repairs etc on the Northpoint radios.
those pp-1s, 2s and 3s are great !!! (a little pricey) ....My guy tells me that for some reason he is having a hard time getting them right now ? ....I'd like to get 2 of the 4x20 second ones but that can get a bit expensive )-: time to start using my brain and figure out how I might be able to make my own noise toy goodies maybe out of a small mp3 player ? ....Just like the easiness of those PPs
Believe it or not, Radio Shack has a little repeat kit. I think it is a little 20 second one. I was fooling around with it and actually put it in a customers radio. It runs off of a 9v battery so no problem! It is really generic though and the sound quality isnt really good, but could be a decent start?
thanks dirt dude .I'll take a look see into that.recorder
HMMM ? take the mic off and wire a stereo plug (mono) in it's place ,take the speaker off and wire one to audio and one to ground ......Hmmmm .......could even find a 9 volt source in the radio if need be or close enough anyway ....maybe with a little practice on my part I would think it might sound damned good ? ....you got my brain go'in now Dirt dude. (-:
You are on the right track....... The hard thing about the quality is dependent upon your volume level and clarity of what you record to it. You will have to play with it to get the levels right.
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
