The amp keys but no modulation...I personally setup new. I did the conversion well over 8 months ago. This amp was keyed on too many times with sever SWR issue's. The guy I set it up for recently came to me with a rx issue with his radio and I found the swr's were off the meter. Replaced the antenna and everything with the radio is ok.....weak but ok.....the amp however is not...exteral frequency counter shows a goofy number when keyed up on...
where should I begin?
Thanks
Cas
Thanks
Cas
