Texas star 500v issue
hotrod
Feb 16, 2007
2,534
408
93
n.w pennsylvania
Had this amp for couple years worked great. Then one day I went to use it and all the lights went out and power dropped to nothing. I checked coax ,fuses, connections.is this worth fixing
More than once I have seen a foil trace along the front edge of the front circuit board burn and cut the power to the power switch. Not a common failure, but put a meter probe on the exposed pins of the power switch. If you can't see any DC voltage there, something has overloaded that foil trace and blown it like a fuse. Problem is that this trace is on the bottom side of the pc board where it can't be seen. If that's what's going on it's probably only the tip of the iceberg, a casualty of some other shorted part, like maybe a RF transistor?
And if you do show DC voltage at the power switch, the fault is elsewhere.
Reactions: Dr. Frankenstein
