Texas Star DX 500v power supply?
Only if you can turn it down to 14 Volts.
And if this one is a "competition" power supply that delivers 16, 18 or 20 Volts to the amplifier, the Texas Star will overheat and fail.
Fat Boy makes both regulated versions you can turn down to a safe voltage *AND* the unregulated versions that put way too much voltage on it to be stable.
Yes, there are amplifiers that can tolerate the higher power-supply voltage, but Texas Star is not one of them.
Reactions: Chevboy0167
Thanks for the info nomadradio...the one I have is regulated and does 12- 16 volts. Should I go up to 75 or 100 to be on safe side?
EX 500V
Output Power with 4 watts input:
250 watts
Aprox. Power Output with 20 watts input/
Aprox. Max Current
500W/45A
4-2SC2879
These transmitters are designed for mobile or base, powered by the 12 volt vehicle battery or 12 volt regulated power supply
http://www.texasstar.com/CWmed.html
It will pull more than 45 amps. And even if it only pulled 45 amps, I would want at least a 60 amp supply for it. You don't want to run a supply that close to maximum all the time or it won't last very long.
Yes, go up to 75~100 amps if you can.
I have checked several Texas Star 500 amps, and they will easily pull 45 amps with very low input drive ( 4w dead key with 20w PEP).
I generally see these amps draw up to 62 amps with a high drive radio.
Reactions: 999
