This may be dumb..... (?? why do CB ops use LSB most of the time ??)
guitar_199
Mar 8, 2011
1,071
1,503
173
Deer Park, TX
I've pondered it a few times but never really put much into it.
I know that most hams, above 10 Mhz, use USB and I've never really thought about it.
But something hit me just yesterday.... and it makes me wonder if it doesn't have something to do with it!!!!????!!!!!
Before 1977 (in the 23 channel days) it seems channel 16 was adopted as the SSB channel.
Ch 15: 27.135 MHz
Ch 16: 27.155 MHz
Ch 17: 27.165 MHz
So,from Ch 16 to Ch 17 there is only a 10 KHz gap.
But downward... to Ch 15 there is an RC channel... but if you look at it a little myopically... it is a 20 KHz gap.
So if you crank up the ALC in sideband.... you have (effectively) 20 KHz to the next channel... leaving a little more room before you run into the next channel.
When 40 channel radios came along...... everybody just whirled that old channel selector up to 37, 38 and so on.... leaving it in LSB...
Like I said..... the may not be the reason.... it may even be goofy...... but it makes me wonder!!!!!!!!
Any comments or thoughts ????
Bob
I've wondered that myself sometimes. Maybe old habits die hard ! Seems as if LSB would be a good place to meet and then jump up to the USB to not be disturbed as much. There I go trying to think again! LOL
Just my understanding, could be wrong.
Before PLL's, to add the other sideband, it was required to use more crystals (expensive), so SSB gear for a given band typically used just one sideband. A convention was chosen to keep everyone compatible, and I think the split at 10MHz had to do with keeping certain mixer products out. It was my understanding that much of the CB gear was designed around the lower frequency ham gear, not the higher frequency multi-band stuff, and naturally LSB became the sideband of choice because of already-established designs that nobody could justify changing. Unlike the multi-band radios that had to worry about mixer products showing up in bad places, CB is a single band and they didn't need to worry about the mixer products landing where they shouldn't. This allowed them to stick with the simple single-band designs. Once PLLs came out, having both LSB and USB was cheap, but the common usage remained.
Ch 15: 27.135 MHz
Ch 16: 27.155 MHz
Ch 17: 27.165 MHz
Bob
Hams used a scheme when a radio that commonly used a 9 MHz IF, that the radio would only require one carrier oscillator crystal, to operate above and below the IF, if the opposite sideband was used. This is why bands above 9 MHz use USB and below, LSB.
I think the use of LSB by CB operators, is similar to why the British, drive on the opposite side of the road, than the US and use right hand drive.
If you weren't on the CB radio right after they switch to 40 channels, it was due to being on LSB ch.16 (27,155) and only SSB at the time of the 23 channel radios.
Everyone stayed on LSB until 10 to 20 or so years later people populated to USB on the freeband frequencies.
Reactions: FlyBoy50
I forgot to mention......
At the time of the 23 channel radios, there were people using Ham radios on 11 meters using (Not channel at the time) any frequency they wanted from 27.265 to 27.999 and any thing below channel one to 26.000.
So there were people already using the freebands before 40 channels became available all over the US.
Another thing I can remember was about a fine, a guy with a club on 26.175 had, he was asking for money (postage) just to send out the paperwork for the club. No fine for being off frequency, use of ham radio, or power.
PS.... 27,145 is the RC below 27.155, that was also used by those that knew how on a 23 channel radio.
I got into CB right at the peak of the boom. Not because it was faddish per se, but because I'd been into every other area of radiocommunication up til that point and it seemed a natural tool to add to my toolbox.
Became acquainted with a lot of the regional operators. There were several classes here. One in particular was the social butterflies. Another, the serious radio operator who wanted away from the butterflies and all their drama. Still another was the person who used the radio for business or travel purposes (i.e., truckers).
Etc.
What I discovered was than one in five of the "serious" class was using some model of ham rig on the Class D allocation, and the lion's share were FT-101 models of some sort.
Two notable exceptions. One was an FT-901DM owned by an operator south of Canton, Ohio. Putting one of these on 11 was not the same as adding the band and TX capability to a 101 - it was considerably more work. The other was a high school buddy. He and his divorced father operated a complete Drake 7 line station into a 4el Yagi at 50ft. They never got stupid with it - and were never cited.
For grins, look at the cost of a Mk IVA back in the day. Then look up the Drakes. ALL the pieces which were available including the amplifier.
LSB, really? 99.99% traffic here is on USB
The exclusive use of LSB seems to be limited to the USA, Canada, and Australia & New Zealand. Everywhere else in the world USB is far more common, and in most of Central and South America both USB and LSB are used......if you tune to a frequency like 27.415 or 445 you'll get English on LSB from the US or Canada, and then switching to USB it will be Portugese from Brazil or Spanish from elsewhere in Latin America.
As far as the "why" of why LSB is the go-to mode in North America, I've heard many different stories over the years, including several which have been touched on in this thread. I think at the end of the day it just comes down to old habits........and whatever the original reason for using LSB in North America was, it is long forgotten.
Reactions: FlyBoy50 and Gman
