tram d201` hand wired vox version
Jul 9, 2008
10
lost power and swing about half as much now tubes are ok alot of money in this radio all new caps most resistors any ideas ? also has been aligned etc.
how is the ssb power is it ok or is it gone too? if it,s ok then check out the compresor cicuit their are two diodes their that can go bad....hope it helps
Tram D201
My Tram had the same issue. It was the 12BY7A tube socket for the driver. Cleaned it up and realligned the tube pins. Was only doing 1.5 watts on low power. After I cleaned the socket and tube pins it runs 3 watts on low and 12on high and is back to normal.
    63Sprint has left the room.
