Tram D201A help please-tubes light up but nothing else comes on
Adamf
243
30
38
71
Hi all, I received a Tram D201A that was supposed to be working and when I turn it on ALL the tubes light up but no power that I see anywhere else, no meter lights light up, so sound, controls appear to do nothing. The radio has 3 fuses a that I see and all are fine. The switch that I believe disables power when you lift up the top lid I suppose has been bypassed as it does nothing and the fact that the tubes light up with top off I believe confirms that? I know this is a stupid question, where can I start? I do believe it was working when shipped, pictures were sent of it all light up. Maybe some kind soul can offer some help. Thanks for any help. Adam
Thanks KneeBiter, pictures posted. It does not have good looking work that has beenm done inside. Adam
Yes, it's had some work done and really crappy work at that. I see some solder pads that were burned away so they had to jumper a few spots. I thought I had found the problem just now, I noticed the grey power resistor in the picture had one end that had been soldered but it did not hold and was not making connection so I ranIMG_3998.JPG a jumper wire and it did help a tiny bit, nothing more lights up but I heard a slight hum from the power supply area and I got some slight crackling from the speaker but that's it. Adam
Can you put a frequency counter's input onto the center pin of the top socket at the rear of the crystal board? That one is the 21 MHz output. If the signal is not there, the radio won't do much.
Does the S-meter zero set trimpot work right? If not, this suggests an issue with the 14-Volt power supply that resides on the BA plug-in board alongside the 6L6 audio tube.
Hi, when you say the top socket at the top reer do you mean where the last crystal is? It's soldered in if so, where do I attach my frequency counter? Thanks, Adam
FYI I was able to adjust the S meter zeronig, I can move it up and down and zero it so that part of the circuit is active! Adam
Hi, thanks for the clarification. Do I unplug the RCA plug and test at the plug or jack? Thanks, Adam
