TRC-457 SERVICE MANUAL
Copycat32
NNJ32
Feb 9, 2024
123
51
38
66
Northern New Jersey
Hi all.. I just acuiweed a trc457 totaly vergin never has the cover off.. Need to go through the audio as its clipping so bad I can't get more then 20%audio out
Looking for a sevice manual and any tips for the audio
Thank You
73s
Service manual available here courtesy a forum member who has since become a silent key:
Tips and tricks from another forum member's web site:
I'm in the "It's old, recap it!" camp regarding the 457 and it's electrolytics. Others may disagree. I do recommend replacing C179 (2.2 microfarad tantalum) with either an electrolytic or a higher voltage tantalum. But that's just because I had one explode when I had a radio keyed up.
Now I'll shut up and let the people who actually know something chime in.
Use the TRC458 factory Service manual posted on this forum. Identical chassis no digital clock.
unit_399
Realistic TRC-458 FACTORY Service Manual
- 399
Thank You ill check in to it.. Looking at Klondike mikes for a kit
Reactions: AudioShockwav
I recapped the power supply with bigger caps recapped the audio section with audio grade caps.. replace c179 with a 50v 2.2 electrolitic.. Did a minor mod on the amc still intact and working so far all working great want to finish recapping and do an alignment almost hat to do anything else as uts working so great compared to when I first got it
