trying to correct internal counter -
1iwilly
Sr. Member
Dec 7, 2008
915
653
103
64
hello to all new dilemma well i like my things to be perfect cobra 2000 the receive frequency is on point both on the built-in counter and on the external freq-counter SSB is also on point the issue is and i would like to get it fix is that on transmit the built-in counter is off instead of 27.2050 it shows 27.2045 i bought it this year with a few issues got them all sorted out this is the last thing it needs to be correct any help/guidance
Reactions: 357magnum
Does this unit have the clarifier locked for receive and transmit or does it only control the receive?
when i got the radio it was unlocked i put it back to stock took the extra channels out too
If you use the clarifier and set the receiver to read 27.2045 and then transmit does it show the same as the receive setting it should? It should also show the same offset on all channels. The frequency should also show the same transmit frequency on an external counter as it shows on the Cobras frequency counter. But reinstating the unlocked clarifier so it works on rec & trans. would or should also cure the issue unless there is something else going on.
Ok after further looking to see where the problem lies previous owner change the crystal to a 11.1125 I had a spare original one put it in now it looks better except now on tx it ends on 52 on am look at pic on lsb and USB but on external frequency is dead on
update i got it where it suppose to be 27.2050 on rx and 27.2050 on Rx i had to use a second frequency counter while going back and forth from tp-1&tp-3 on 1 counter and second on so239 i feel better now thanks for the replies now i just need skip hehehehe
Reactions: guitar_199
  • @ Hambones amps:
