ts 120 kenwood modif 11 metres
juanito
Mar 1, 2013
35
bonjour
je cherche un tutoriel complet sur la modificationdu ts 120 kenwood pour la bande des 11 metres
merci, cordialement
The mod works but frequency read out does not show 27 mhz.
:glare: Unless the 3 radios that I did using this mod show different readings
good deal I could not get the only one that was modded to display the 27.
Of course the rig was well used and worn.
If I remember it was a secret CB mod and only a one wire mod with a switch,
Switch in one position was 10 meters switch on other position was 11 meters.
If I remember correct. (Did this over 15 years ago) It was a yellow wire to be cut and switch added in circuit.
  • @ heartbreaker3473:
