Just for the hell of it I ran all the info into AI. Everything I've experienced and done so far. It asked for pics of both sides of the board so I uploaded them. AI says not to replace the audio chip because according to me test procedures it should be okay. The reason is that if I increase the gain control, the noise gets louder which means it's amplifying it;s own noise. That's good. AI is telling me that the most likely problem is a weak element, forcing me to turn up the gain which is increasing the noise. So, I plugged up a plus three and made a quick test. Sure enough, the4 noise gets loud out of the plus three if I disconnect the element and turn up the gain. Apparently, all the turners are noisy, but you can't hear them because they overpower the noise. Also, AI told me there are replacement chips out there that are also obsolete, but there is a way to convert to an 8 pin chip that is much lower in noise and has more freq response. When AI told me I'd have to rewire a couple of things or make a addon board, I told it it was mistaking me for a technician. AI laughed at me and apologized. Anyhow, seems kinda like it makes sense with it being a weak element. After checking, I see it's already been replaced.
