Per my post in the UHF/VHF forum, (http://www.worldwidedx.com/vhf-uhf-bands-vhf-uhf-rigs/58461-ftm-350r-vs-tm-d710a-should-i-get.html,) I will be purchasing either the Yaesu FTM-350R or the Kenwood D710A. Which mount method should I use: drill hole, magnetic, or trunk? I have listed what I understand the advantages and disadvantages among methods below; please advise or correct as necessary. Thanks.
[FYI, my car is a 1997 Dodge Intrepid four-door sedan. I will most likely choose the Comet CA-2x4SR, CR-320A, or CSB-750A, based on various reviews on worldwidedx.com]
Drill Hole
Advantages
-Takes advantage of center of roof for best tx/rx and ground plane
-Feed line remains inside the automobile w/o running through door or window
Disadvantages
-Need to ensure safety during installation
-Need to ensure rain does not enter through hole for antenna
-Cannot move mount between cars
-Reduces resale value
-Does this method reduce safety of remaining in vehicle during lightning storm?
Magnetic
Advantages
-Can move mount between cars
-Does not permanently alter car
Disadvantages
-Feed line must be run through door or open window
Trunk
Advantages
Disadvantages
-Does not take advantage of ideal tx/rx or ground plane location
Do ground planes matter that much for U/VHF operation, or is this mainly a HF concern?
Thanks to all for your help! I look forward to going on the air soon!
73,
KC2TUA
Drill Hole
Advantages
Disadvantages
Magnetic
Advantages
Disadvantages
Trunk
Advantages
Disadvantages
73,
KC2TUA
