Uniden 510xl rx mods?
I got 3 of these (phillipine) going to some local jeeper 4x4 Bros. So if you refer to the thread I put up about how I rebuilt the final and driver of a Kraco kcb4007 after naysayers said it couldn't be fixed to talk right, you will see me disregarding comments like this.....
I always will slap lipstick on a pig and name her Betty.
Reactions: secret squirrel
The 510XL is not a "perfect radio" to do a receive mod on...
So you have the Discrete one or the SMD one?
The SMD one is not a good candidate.
The Discrete one is great - for it has several "RX tweaks" in it you can do to help but it will not be a selective stellar performer able to pick out your friends from all the engine noise the vehicle will produce - it just knocks everything down aggressively - the SMD ones did away with any variables to help find the threshold of noise to signal you could use to help - the older Discrete chassis is the best one to work with.
The older one used the TDA1220 AM/FM Radio on a chip - if you have that board, there's hope.
Similar to the 510e only without the Electret condensor mic element; attached is the 510 SMD version with the ANL magnified to show how the ANL and Detector side worked.
The thing about it is that naysayer as you put it has probably forgotten more about radio mods and repair then most of us even know. The 510 and 520 radio's for the money are great little purpose built radio's. They will never do things a 300 dollar radio can but that's ok, they were never intended to do so in the first place.
Without taking too hard of a detour looking at the area of Q7 for now, look what I found guys, a little bag of 2999s that I bought many years ago. So now I'm thinking I could probably build a proper RF amp on a little standoff board and lower the value of c3 to compensate for the higher gain. It's not like these Philippine models don't already have to stand off boards right on there.... Yes it's a lot of work for a small cheapo radio but I kind of like things that come out the other end as Frankenstein.
Board shots of a 510XL...
Tried to get the 4 corners well enough...
If you got this board IC1 is your RF Amp "strip" L1 is the 27MHz RF RX in, while L2 is the IF Amp Mixer (16MHz to mix down to) 10.7MHz for the TDA1220 AM/FM Radio on a Chip which then coverts down to 455kHz IF for AF out to the Volume control
The Varactor is 1SV73 - 18pF 1V - 1MHz - then drops to ~8pF at 3V at 1MHz
