Uniden 68 RX issues
longhaireddwb
Oct 8, 2008
555
30
38
Colorado Springs, CO
Hi all.
Picked up this Uniden 68 and used it for a couple days. Its a used radio. Got it for pretty cheap. The other day the RX died. So I took it out of the truck and put another radio in the truck. Same mic and power cord. Anyways, I've got this Uniden home and injected a signal into the SO239 with a sig. gen. and nothing. So I spent some time checking voltages on TR's encluding the first IF and the reverse diodes as that normally where I find these types of problems and all tests fine. ???
I decided to bump up the power, so I injected mv of signal instead of uv of signal and I can hear it RXing. The more I input the louder it gets, volume and squelch controls work as they should as long as I'm injecting the higher amplitude of signal. Also the filters/cans all adjust the signal up and down so they seem to be doing what they should.
Please let me know if I'm thinking on the right line here... If I can RX with more amplitude, than this confirms that all TR's and filters (455 and 10.7) are working as they should. And the issue has to be a bad connection somewhere. All caps should be ok too, right?
So am I think correctly on this? What can I be missing? I've spent a few hours going thru the board touching up solder joints and flexing the board and no changes. Please help me to understand what "MIGHT" be a place to look for an issue like this.
BTW, if I inject a AF signal into the audio chip all works as it should so this is telling me that the problem is between SO239 and audio chip. Right?
Thanks for any help. I'd say I should stop buying used CB's for cheap but I just cant help myself. Ha.
Jerry...
You know i never did check the PA. It does tx with no problem. Thanks for pointing that out. Honing some razors right now but will try to pull the uniden out and try the PA. Ive solder about everything the the RX section but guess i can go over it again.
Your receiving circuits might have been smoked by a strong signal.
Some radios will not receive unless the microphone is plugged in.
The volume and squelch work when you crank a big signal into it. Does the RF Gain control have any effect when you turn it.
If not, this points to trouble in that circuit. And if it DOES turn the receiver signal up and down, that would point to trouble elsewhere.
  • @ heartbreaker3473:
