Uniden 78xlw with agc problem
Harley3315
Well-Known Member
Oct 22, 2015
246
32
58
44
I'm going to assume this is an agc issue I have to have the volume full boar to hear any normal static i can hear my locals blasting me out of the chair when they key up. When the other stations I talk to 20 miles out key up I can hardly tell some one had recapped the radio with junk Chinese caps took those back out and put in nitchicon caps for starters it also had been schottkey diode swapped and a 2n2999 in tr7 spot those where all swapped back to stock d1,2,3 have all been changed as well as tr8 tr9 tr10 where to go from here??
VR1 is a favorite target for tweakers. Mainly because cranking it full clockwise appears to bring up the receiver sensitivity. Correct adjustment is usually about 1/3 below the full-bore setting. Turning it too high gets you the opposite problem. Excessive noise and a tendency to overload on strong signals.
A louder noise level doesn't allow you to hear anyone any better.
Then again, if someone turned it the wrong way, this will cripple the receiver's sensitivity.
Not sure how much. Never tried it.
