Uniden Grant need the schematic.
dss56
Well-Known Member
Sep 27, 2010
434
125
53
57
I have a Uniden Grant with the TA2222A audio chip.
There is no audio modulation and no pa audio.
Receive audio is fine and external speaker audio is fine.
The schematics I have found on the net are not the best when enlarged to read the parts is blurry.
So a good copy i need if possible.
I'm looking to replace cap C-186 C-153 C-18 C-95 and see what happens.
I wanted to check out schematic wise before I change them 1 at a time for the modulation not working
thanks
Way too many radios named "Grant" with that audio chip in them.
Is it the 1980s Grant radio with the PC-409 circuit board?
Or a Grant XL, Grant LT?
All of them use the TA7222P audio chip, but the circuit boards and schemos are different.
Reactions: walterjn
thanks nomad same here when you blow it up it gets blurry and hard to read the components # thanks
Hope someone will chime in on a good copy
Yes Chris still blurry thanks the one Kopcicle posted if blown up you can read so all make a copy of that one as the ones on cbtricks is the same blury when enlarged
