Uniden GrantXL-Philippine version
Dmans
Jan 22, 2017
1,478
1,986
173
Georgia
All,
I have another project. This one is a Grant XL with an MB8719 PLL. The owner said it was working fine, made a strange noise through the speaker while receiving then receive was gone.
I found this unit had been highly modified. I.e. 10 turn clarifier, extra channels on 2 of the front panel switches and a variable power potentiometer in place of the S/RF-SWR-Cal knob.
I found the 10 turn potentiometer was bad. No resistance on either outside terminal to the wiper in any position. It was wired directly to 8vdc and grounded to the top of the 11.325 crystal. I replaced the 10k ohm 10 turn potentiometer with a new 20k single turn pot and added in the missing R174 and R175 resistors. It still has 8vdc on the wiper in TX and RX. The problem is after aligning the oscillator(s) the clarifier will slide up but will not slide down at all. Example: Aligning the AM oscillator at 27.185, the clarifier will slide up to approximately 27.245 but will not come back down to 27.185 much less slide below channel 19.
In looking at the schematic (as found on CB tricks) I noticed what I think may be an error. If not, this may cause the problem I am experiencing.
Below is the area of concern.
In comparison to the 148GTL schematic below;
I was leaning towards a bad varactor diode prior to see this strange routing of R174 and R175 on the Grant schematic.
Any thoughts on this?
73’s
David
Why do people list the Uniden Grant XL radios as Philippines or Philly built???
If I remember correctly they were all manufactured in the Philippines ... just saying.
Reactions: S&W357 and walterjn
Unbutchered the butchery that was related to installing the 10 turn clarifier. I'm not sure why people remove components to make the slide work greater than 3 or 4 channels but I suspect it is impressive to the customer that they charge to do it. Makes them feel like they are getting their money's worth I guess. It sure makes for a terribly unstable clarifier though and tends to eat components.
I installed a resistor in the "R149" position. A 10k ohm part that was removed. It still ended up with more than 1 channel each way but this is one of those "freebies to help somebody out" deals". Last time I tried to make one as close to factory as possible for this owner, he was not real happy though the radio worked 100% and will probably last a long time now. Maybe because I took away something he paid for??(High dollar butchery!) I think he took it back to the butcher and had another round of butchery installed. Oh well, you can't protect people from themselves!
This Grant has other problems I don't care for but my deal with this one is done. It will spontaneously combust soon from all of the butchery.
73's
David
