Can someone tell me without getting to technical, if possible, how to drop the wattage down from the current 5 to. 3? I do know I will have to leave my wattage/power meter in line while the cover is removed. Wheather it's the bottom cover or top depends on wheather where the adjustment pot is located. I'm also assuming once the cover is off I will have to plug in the radio and turn it on. Ok, so back to the question, where exactly is the wattage adjustment, and how do i drop it down from 5 to. 3? If you can give me instructions ie 1. Open cover. 2. Turn on radio, and so on. I'm not tec savy and my physical limitations make things difficult but this is something I think I can do and if not I can at least walk a friend through it. thanks to my wwdx family.
