Uniden PC78 Elite Troubleshooting
RokGoblin
New Member
Jan 16, 2026
5
I'm looking at the following schematics for the Cobra 29 LTD CLassic since I can;'t find any specific to my Uniden PC78 Elite. Early 2000s model. https://cbtricks.org/radios/cobra/29ltd_29ltd_st_29wx_st/graphics/cobra_29ltd_sm.pdf
My friend gave it to me after he fried the final(?) by keying up without an antena hooked up. In this scenario, is the primary Q502, and the final Q501? Which one typically burns out and how can I test with my multimeter before tearing into it?
TR14 and TR15 from the schematic both seem to be the same as the Q501 and Q502 positions on my Uniden, but there are no Transistors in the expected location on the diagram (from cobra_29ltd_sm_sch.pdf) on the heatsink. The Q501 seems to be a standard TO-220 type, but the Q502 is different and I can't find a data sheet for it.
Looking at Q501(TR14) it's already an IRF-520 from the factory, but I am not able to read the markings on the Q502(TR15) transistor (yet), but it seems to be a 1957 by the center hole. My friend said it was never repaired or modded, so why the IRF-520 instead of the 2078(?) from the schematic? Did they add the IRF-520 mod themselves in the 2000's?
I'm not trying to upgrade anything and was more hoping for a direct solder in replacement. I am not opposed to the upgrade, I just don't have the test equipment other than the multimeter.
I need a dummy load to test with since I don't yet have a CB antenna, but any other tips are appreciated.
For what its worth, today I was messing with my Uniden PC78LTW that was from 1994. That one has a 2166 final in it on the back. You can usually grab a multi meter and probe any of the 3 legs to see if there is a direct short between the legs. (I believe its best to desolder the legs off the board before testing.)
The driver usually never goes out, but most likely the final. Maybe get a dummy load and a watt meter first and hook it up and double check what its doing. I bought a parts RM Italy 203P recently and the person said it stopped outputting power. To my surprise, the fuse holder inside was loosely grabbing the fuse. (This was after removing the mosfets to put others in, but once I replaced them and it acted the same, I then realized the loose fuse holder. DOH!) :)
Neat radio you got. I was on the lookout awhile back for one, but I will be happy with this old PC78LTW.
With my version of logic, the schematic is telling me the signal flows from TR15, to TR14, or in my case Q502 to Q501, so the final would be Q501. I seem to be quite lucky in that this one has an IRF-520 in that position.
So it seems a direct solder in place might be possible without additional mods. Is this correct? I will borrow my friends antenna to test things out. I gotta find a local elecrronics supplier in North Denver now.
It's really hard to tell, but here's the final (see photo). Maybe they did start making it with that part in the early 2000s based on availability and the existing mods.
I am about 99.999999% sure that the IRF520 was never used in that model from the factory. This is most likely after-market, either a botched repair attempt or power upgrade, but if your friend had it from new and never had any mods done, it does raise an eyebrow a bit. As for your current issue, any one of several parts SHOULD drop in. 2SC2029, 2SC2078, 2SC2166, 2SC2075, and 2SC1969. The 2SC2312 can drop in, but would not give as much output as it requires more drive. As for testing, since what you have is a MOSFET, you would need to build a circuit to test it, or use a component tester that can ID MOSFETS. Easiest way in this case is just drop in one of the above transistors and see if it fixes the problem. As for the driver, it CAN blow, but much lower chance of that. 2SC1957 and 2SC2314 are the two usually used there, with the 2314 by far being the most common.
Reactions: RokGoblin
Thanks, my friend said maybe he bought the "Upgraded" model on Amazon, it was a while ago, LOL. He said it was new in box.
Newer Uniden/Bearcats do seem to be using MOSFET's as standard, at least in the larger models. I've not looked that closely at their smaller models.
Sweet, so I'll just drop a fresh IRF-520 in there. Thanks for the follow up. Do I need to be concerned with testing anything before I connect an antenna and test out the TX/RX?
Yeah, there is. The DC voltage on the gate terminal of the MOSFET controls the current the MOSFET draws. The exact voltage needed falls in a range of three to three-and-a-half Volts more or less. From one batch of these to the the next this will vary as much as a half of a Volt. But it's a stupidly sensitive parameter. That half of a Volt can span from not enough current to max smoke overcurrent. It should be set for the desired current drain while transmitting, and not for a wattmeter reading. And certainly not because a buddy says "3.347 Volts exactly". Might be right for his radio, but not necessarily for yours.
I would probe the foil pad where the new transistor's gate goes BEFORE you solder it down. If it's set much above three Volts, turn it down to that setting as a safe starting point. And if it's too high, find a way to turn it down before you solder the gate lead to the circuit board. If that voltage is too high, it could smoke the new transistor before you can react.
As mentioned, you will need to check the bias level. There is a POT near the final for this purpose. Also as mentioned, different makers/batches of IRF520's can have different bias requirements. Short answer is usually yes you can do a drop-in replacement, but be aware its not 100% of the time. Its always best to do the test.
    Scheduled for Jul 4, 2026 Saturday Live Streams:
    To celebrate the 250th birthday of our great nation. We are giving away not just one, but multiple antennas! The Grand prize is the CaHR-Tenna Hydra Antenna, along with several other antenna prizes that will be announced throughout the giveaway. Whether you're a new ham, portable operator, POTA activator, or an experienced HF operator, this is your chance to upgrade your station. Prizes Include: HRA Hydra Antenna (Grand Prize) Additional antennas from HRA More prizes may be added during the giveaway!
    CQ Worldwide VHF SSB/CW Contest: 1400Z, Jul 4 to 1400Z, Jul 5
