Unknown radio identity
RT2020
121
19
59
Was curious if anyone can identify this radio, guy wanted me to help him, he didn’t know what any knob or switch did because of the graphic being gone, he told me it was a Galaxy but it doesn’t match any galaxy layout, I figured everything out but was wanting to help him find a graphic for it. It is a SSB radio, thanks
RT2020 guessed good. I too believe its a Superstar of some sorts. Maybe the 3900?
Superstar SS-3900 Black
Knob/switch layout looks same as a POS SS158-EDX I had
Reactions: doffo
I concur, looks like the old SS-3900
Reactions: doffo
It’s funny how they change the layout from time to time, this one has the 6 bands on the knob and the upper right switch is Roger beep, the switch to the left of that is a tone.
The Hi/Lo should switch bands on some later models once it has been converted that should give you 12 bands
Can you find a EPT number on the board?
This doesn’t have the high/low switch, that switch is a tone control, I didn’t see the board number but TM86 found it
Pearce-Simpson Super Cheetah
I had dozen of them on the bench.
That service manual should help.
Mike
Thanks, that model matches the switches better so that’s probably it, I wonder if someone put a Roger beep on the channel 9 switch on this one because I can’t find anything that matches up.
  • @ Hambones amps:
