Up/Down buttons on Midland XMT115 mic
LOL what I meant was swap the up/down buttons on the Midland XMT115 mic.
I’m not touching the President Bill mic, it’s perfect. :)
Oh duh....you’re right, just want the left to be down, and the right to be up. But you are correct, the buttons will still point the same way.
If the plug end is able to be opened or accessed.. couldn't one just swap the wires at the plug if you know the mic wiring?
The mic is only wired with 3 wires. It has a mic element and 3 switches, so the transmit wire probably does all 3 switches. The radio can tell what button is pushed by the resistor in line with the button. I suppose that the resistors could be swapped. But I can hardly see them. Haha!
Reactions: Blackcat630
  • @ Spanish:
    Where do i upload schematics
