I don't see why not , but first you need to get the power up first with the mosfet to do so . If you only do what cb tricks tells you concerning a 29 , I doubt you will see more then 2 watt DK to begin with , more changes need to be done to get the dk up in the first place. If the variables will work with the 69s , they should work as well with the mosfets. Mosfets
