VHF UHF sat
Se7en
Jun 27, 2010
4,573
223
Ca
so, i got my kenwood tm-d710a all hooked up mobile working great.
what else can i do besides talk simplex and talk repeaters.... any sat or...other stuff to listen or talk to ...? it appears on the B side i can listen to 220mhz,500mhz,700mhz-1200mhz.
AO 27 and SO 50 are the only FM sats left working now and they transmit and receive on the same frequencies with SO 50 needing a tone on the uplink. AO 27 is only available on ascending passes in the northern hemisphere for 7 minutes about when it crosses 30 degrees North latitude
If you are going to try working the satellites, let me give you a word of advice, DO NOT TRANSMIT UNLESS YOU CAN HEAR THE SATELLITE, and open your squelch. check out this site for recorded satellite passes and some info on working the birds. General Satellite Recordings
Ya but Dave, the self proclaimed Satellite Instructors might disagree about full duplex, they would rather you QRM the bird than hear yourself or anyone else for that matter.. :bdh:
  • @ heartbreaker3473:
  • @ AudioShockwav:
