Is there a good driver/final combo for this old late 70's rig? It has a pretty anemic C2028 driver / C2029 final pair in it now...
The pinout on the C2028 driver is backwards from a C2166 driver E-C-B vs. B-C-E. The final pinout, however, is the same as a C1969.
Just swapping in the C1969 final w/o any tuning drops a watt or so dead key. The 2028 driver probably doesn't have much on the gain end of things. I guess the C2166 could be used as a final, leaving the C2028 driver in place. Any tips?
*Edit - Looks like the 2166 is about the same power (6W) as a 2029. Maybe I'll just do a contortionist act with heat shrink on the 2166...
JustinD, I know you had to have run into one or two of these...help...
