Vintage CB - Magazines; Ad's, articles, cartoons, etc.
The original-technology standard-power TTL chips it's partly-built from are power hogs and run hot. The chip technology was making progress in leaps and bounds when it was designed, and it also contains a few later lower-heat "LS" TTL chips. One way to reduce the heat a bit is to run it from a regulated 8-Volt external DC supply. This will reduce the power dissipated by the voltage-regulator chip. Won't reduce the heat from any other part inside, but it's the only measure I know to take.
Dynatek voice scrambler ad - s9-1977-08
  • @ heartbreaker3473:
