Weak/stubborn qt40 output
nfsus
Yeah its turned off, touch it
May 9, 2011
606
324
Arkansas
My qt40 works great. As well as you’d want. Until you look at the rf meter. Mic gain is up in the menu. All the knobs are all the way up. If I whistle I hit 40w but talking I hover around 8-10 if I’m loud. The tx reports are great as far as quality goes.
How/where can I crank the audio up??? It’s killing me!!
What mode?
ssb does not read full power unless you do a constant steady noise/tone, it may read full power on voice peaks, do a search on google, plenty of posts about it and why, and only a good meter will show it.
That meter is stingy wih reading peak power in the lowest power scale. I'll guess that if you select the 200 scale with the peak switch turned on it's a bit livelier. At the bottom of the scale, though.
Hahahaha I’ve never heard anyone call dosy stingy!!!! I’ll check it out though
