Retevis is giving away ANOTHER RA89R Radio for Independence Day! Click Here for more info!
Bingo!
That is what I would choose - too.
Draws 35 amps; OK for the electrical system.
Decent for both AM and SSB performance too.
That amp requires no more than 30 watts input for a clean output; so a RCI 2950DX should work out fine. The RCI isn't an AM audio monster like the Magnum; but with a decent mic it will be just fine. The Magnum output is too hot for the amp; the dual MOSFET output transistors will swing the output too high - even when turned down.
The Texas Star 350 'Variable' model is one to stay away from. The non-variable is what I have; you won't have to worry about burning out the variable power control.
Either an Astatic D-104 Minuteman II or RF Limited CR-577 mic would also be what I would do with this particular radio for best AM/SSB performance/transmit audio. The CR-577 is better - IMO - I use one in my mobile . . .
the variable can be replaced with a better one or a cap with the proper value .
i drove a 500v (4x2879) to its full clean power capability with just 16-17 watts pep . i doubt the 350 2x2879 would require more .
Two '2879s?
If you can't drive them with about 4 or 5 watts (as in a stock radio) to full useful output, you're doing something wrong. They just do not take much drive for normal operation. Take a look at the spec sheet.
Texas Star recommends 25 watts for optimal results for the 350 model. 30 watts would be the top of what I would put in for CB.
BootyMon: I'd like to see a link for modifying the variable on these Texas Star amps. Don't doubt you for a second - just like to have it here as a reference for others. Thanx!
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
