What is Your ANTENNA FARM?
Outside
ASP-350 groundplane about 50 ft. high.
Discone antenna up about 25 ft. for VHF-UHF
Attic
8 element 144/440 Yagi on rotor
2 meter Square Loop
2 meter groundplane
6 meter hamstic dipole on rotor
11 meter dipole
Mobile
2 meter magmount
2 meter Firestick trunkmount
11 meter Firestick mirror mount
11 meter Cobra magmount
Storage
11 meter homebrew coax antenna
11 meter homebrew inverted V
later today I'll be installing a 102" whip with a 4" spring using a stud mount on top of the roof of my car.
It's not really a farm, more like a pet, I guess. They don't allow farm animals where I live.
Base: 60' tower with 11 element VHF beam
roof-mounted AV-8 Cushcraft all band vertical
160 thru 10 dipole (Cobra Ultralite Senior)
homebrew scanner antenna on tower
6 Meter dipole
A-99 cut for 10 Meters
UHF J-pole
2 Meter J-pole
Mobile: Carolina Cyclone II 80-10 Meter screwdriver
dual-band Larsen 2m/440 on roof of pickup
homebrew 6 Meter base-loaded whip (made from a 2
Meter antenna)
Separate VHF single-band Larsen for commercial/
military VHF
Glass mounted CB cell-lookalike antenna
And that does the job for me! :D
CWM
Base:
Diamond X200A 2/440 vertical @ 30ft
Diamond A502HB 6 meter 2 element yagi @30ft
Par OA-144 2 meter loop @ 35ft
A99 11 meter vertical @ 25ft
20/40 meter parallel-wire dipole @ 25ft
Mobile:
Tech America 2/440 dual band
Tram 2 meter
Wilson 1000 11 meters
-Interceptor 10K for 10/11 meters
-Comet / Diamond (don't remember which one) 1/4 over 5/8 wave 2m vertical
-Ratshack scanner antenna
-Alpha Delta DX-CC 80-10m dipole
-80m full wave loop, laying on the house, through the trees, on the fence, etc...
Mobile:
-Hi-Q 4-80RT, 10-80m screwdriver antenna
-Comet 2m/440 antenna of some kind :)
-Firestik II 4' cb antenna
Portable:
-SuperAntenna 440-80m collapsable screwdriver antenna
-20 meter wire dipole with 450 ohm ladder line
-12' collapsable whip for use on SuperAntenna or whatever else I feel like doing with it.
-Lots of wire and ladder line for whatever other project I feel like :)
mosley ta-33 senior for 20-15-10
solarcon a99 for 17 and 12
modified g5rv(extended) for 80-60-40 and 30
7 element vhf beam not sure on the name
Not the biggest in the world but it does do the trick for now
Base:
Cushcraft A3 tribander for 10,15,and 20m
Homebrew six element 6m optimized yagi
Cushcraft A147-11 eleven element horz. yagi for 2m SSB
simple dipole for 80m
300 foot longwire for whatever freq will tune up into it with TenTec tuner.
3/8 wave inverted L for 80m tunable on 160m as well
Mobile:
Larsen 5/8 wave 2m magmount used as a 1/4 wave 6m antenna.
Diamond dual bander for 2m/440 MHz.
Various Hamsticks for HF bands.
    boog351 has left the room.
