Before the arrival of the SB-220, there was a popular notion that a legal-limit SSB amplifier needed a heavy-duty power-supply that required two grown men to move it about. Heath engineers knew that this idea was based more on amateur radio folklore than on sound electrical engineering principles. They also knew that the average duty-cycle of a human voice was only about 15% when no carrier was present, as is the case for SSB operation. So, why build a 100% duty-cycle, AM, "lock-to-talk" power supply when one was not required? Thus, they designed a power-supply that would competently do the job that was needed. This resulted in a considerable size, weight and cost savings, which they happily passed along to the buyers of their product. At first, some people in the ham community had negative comments about the SB-220's "wimpy" power supply. With the passage of on-the-air time, it became apparent that the power supply would do the job, and do so with a low failure-rate and with no detectable on-the-air ripple. This was no accident. Heath engineers had wisely specified a HV-transformer design that had an exceptionally low secondary-resistance of only 12.2-ohms. This minimized the voltage drop under full load in the capacitor-filter fullwave-voltage-doubler rectifier circuit. Such circuits have an extremely high peak-current to average output-current ratio. So, minimizing the transformer winding resistance is essential for good voltage regulation and to minimize the I2R heat loss in the transformer's windings.
Many hams initially labeled as "inferior" the capacitor-filter fullwave-voltage-doubler rectifier circuit. They did not realize that this circuit has some advantages over the traditional, fullwave-bridge rectifier circuit. These advantages are:
1. Low ripple-voltage. This is due to the fact that, as one capacitor bank is charging, the other capacitor bank is simultaneously discharging, thus, cancelling each other's 180º out-of-phase, sawtooth waveforms.
2. It allows the transformer to have only half as many secondary turns which yields a more efficient transformer design. Here's why: Since a layer of insulating-paper is required between each layer of wires, fewer turns means fewer layers of paper. This allows the transformer to use less paper and more copper. The net result is a transformer that has a high ratio of copper to paper. This makes for a very capable transformer.
3. Excellent voltage-regulation during current-transients, due to the fact that no swinging-inductance filter is used. This is exactly what's needed for CW and SSB modes of operation.
the SB-220 was designed primarily for SSB/CW use ONLY! a cursory read of the high voltage power supply specifications bears this out. the warning against AM/FM operation comes straight from the manufacturer.
"I operate my SB-220 in AM mode and I have never had a problem either".
and you do so at your own risk.
