Which is the best Browning base ever made?
  • Thread starter Thread starter AM POWER
  • Start date Start date
A
AM POWER
Guest
Id like to have one but know which one is the best of them all?
For power output and longetivity?
Thanks
AM POWER
</p>
I like the MKIVA best and MKIII second.Both have great audio.The loudest Browning I have ever owned is my MKIII AM only transmitter.I have been running Brownings since the 70s and have owned over 100.The most popular has always been the MKIII.
I used to have a dual 6BQ5 MKIVA and I am in the process of making the dual tube adaptors so I can run duals in my current Brownings as I like the additional swing..Gives you around 15 watts more PEP.Good luck on your Browning purchase.Hope you enjoy it.
2TX922
IR2622
CDX922
WO922
YG22
LS22
DX22
MM22
LW22
</p>
Your welcome.Well anywhere between $350.00 and $750.00.
As for the dual 6BQ5 you would just have to order two tube sockets and have a tech wire it up for you or if you dont mind a new hole in the chassis you could mount one socket in the chassis next to the 6BQ5 allready there and wire it underneath.I dont know what the RMS reading is.I only compared PEP.If its importent for you to know I will give you an RMS reading later.Take care.
2TX922
IR2622
CDX922
WO922
YG22
LS22
DX22
MM22
LW22
</p>
