Why do dual band antenna always seem to have more gain on the higher band?
It is the same thing as stacking antennas. Since 70cm is three times the freq. as 2m then you should be able to stack almost three times as many 1/4 or 1/2 wave elements into the same length as on 2m. More stacked elements the higher the gain. As for matching, that is all built in and there is no adjustment on most dual band antennas nor is there a need for it.
On most of those dual band antennas you will find a 'lump' or two on the whip, right? That's the 'matching section', or in most cases a small coil. (It's also the reason most of those type antennas have a power limit in a lot of cases.)
(quit waiting for it now, not not, whatever)
