Wilson 1000 roof mount
The coil can break in a Wilson, I’ve had that happen several times from hitting tree limbs and such. Since the coil housing is sealed, I had to cut it open with a dremel and fix it. That left it pretty ugly.
Or the coax could have come loose from the 239.
The mount may have acquired some rust between it and the sheet metal.
But my first suspect would be the PL connector to coax, since this area is so often subject to bending/fraying of coax wire.
Reactions: 357magnum
Bobby ,I had an antenna a while back that had one strand of coax shield wire shorting out causing me grief . It was hard for this old man to see w/out his glasses but I found it .:)
