Wiring Microphone
Motorola1
May 31, 2022
10
67
I have a Cobra 140 GTL It has a 5 pin mic connector on the radio. I bought it at a auction it did not have a microphone for it. it did come with other cobra mics that were 4 pin. I think the 4 pin microphones only have 4 wires , so how do I make I believe the ground connection?
Thanks.
Thanks.
I know that I could use a 4 pin to 5 pin Cobra to cobra Microphone adapter or I could take 1 of my extra 4 pin Cobra mics and remove the 4 pin plug and install a 5 pin plug. The 5 pin plug has a extra pin that is the ground, so maybe I could run a jumper between the ground and the audio shield inside the mic plug?
Does anyone know if this is one way to do this other then using an adapter?
Thank you.
Stock
1- Audio
2- Shield
3- Receive
4- Sw Com
5- Transmit
Astatic (4 wire)
1- White
2- N/C
3- Black
4- Shield
5- Red
Astatic (6 wire)
1- White
2- Shield
3- Black
4- Blue
5- Red
Yellow N/C
Galaxy DC-521S (4 wire)
1- Yellow
2- N/C
3- Black
4- Shield
5- Red
