is this possible ?
would i be able too simply tune my 29 so i could get a 2watt deadkey and 10 swing???? or will i need too solder some stuff in ?
Yes , there are many different things you "could do" but IM guessing you would want to do this for reasons of driving an amplifier ? If so , just dropping the watts down to 2 and the modulation set at 100% would also get the job done without any further modifacations done to the radio.(you would be in the 8 to 10 watt swing range from there) 74s link will work with other mods of the same type caliber.
My choice would be tune it for max performance, then insert a resistor between the output of the modulation circuit and the input of the RF choke which supplies the collector of the driver. Make sure you use half-watt resistors, or double-up quarter-watt units. Select the resistor value that gets the carrier you want. I also tune the 2 coils before the driver for a centered low-carrier "indent" on channel 20. It tends to give more even key across all 40.
    boog351 has left the room.
