148 gtl low carrier
blueridge
Sep 19, 2009
21
I have a Taiwan 148 gtl that I have replaced several caps in. I now have about 3/4 of a watt carrier with about 5 watts swing. I have looked at all kinds of voltages and seem to be stumped at whats causing the low carrier. On SSB it will do about 13 watts max (all watts PEP) with the limiter removed. Anyone have any ideas what might be keeping my carrier so low? Thanks
Bad VR10 or compnents thereabout?
VR10 appears fine but have not had any luck switching out components around it. I have a scope but have no idea where or how to start troubleshooting this type of problem. Any ideas how to narrow it down? I might bring it to you if you didn't mind just to see how you would approach the problem. thanks a bunch
How I read this the radio worked before you swapped the caps?
no. it wasn't doing anything on transmit, I replaced c18 (i think) and brought it back to life but not all the way. i got that hint from a thread here i think. I just can't seem to find the missing link to bring it back completely. thanks
finally, it was the transistor right before the big AM regulator. Changed it out and carrier is now from 0-5 watts. thanks everyone
