Hello... I ordered a matched pair of Tailors 3-500zg tubes from RF parts. I bought them because they were the cheapest. My question is.... the Tailor brand any good?
Thanks. I was looking for economical.As you've deduced, they are the cheapest brand going. That means they are the most economical, and that's good. Are they the 'best' brand going? I really doubt it, the best is never the cheapest.
And just for for grins. That first number in a tube designator such as the '3-500' series, tells you the number of elements in that tube. That means that a '2-500zg' is one hell of'va big diode, or rectifier. A pair of them would make a very high current full wave rectifier and power supply. Bet the required transformer for that thing would weigh a ton.
(I know it was a 'typo'.)
run your taylors for a while save up a get you some Eimacs
no... thats too much drive.you gonan run that into the 3000a7 you got?
Soooo Doc You are saying I can get away with driving the 3cx3000 amp with the SB-220? Actually when I think about it... it should workOh, I wouldn't worry much about over driving things. Unless that '220 is very heavily modified, as in redesigning it from the ground up, you certainly aren't getting that much power out of it on AM (or is that input power?).
