I have questions concerning Amp draw from power supply with 2970n2.. how many amps does your draw at 200 watts out on AM and SSB? Thanks in advance :headbang
The 2970 dx I sold to Chop drew over 20 amps wide open. i even called the supplier to be sure as my 25 amp supply couldnt keep up. It was fine though. Just takes a lot of power to run.
PR
Mosfet, maximum output.Mosfet finals? was 18 amps on AM or SSB?
You're more than likely experiencing stray rf getting into the line feeding your amperage meter.Ok, then why is my radio drawing 49 amps out on 240 watts? I have 2970n2 with mofsets.. on SSB it should only be drawing 18 amps at 200 watts according to what you said... what gives.. ??? is something wrong inside my radio.. it would make sense if mine at 200 watts drew only max 30 amps.. why is mine at 200 amps on SSB with Mofsets drawing so many AMPS??? Pleae help LOL.. I can't figure it out..
thanks :headbang
What is the swr of this rig?on a 70 amp power supply..(Astron) this radio does 315 watts SSB and draws 55 amps..go figure.. it should what draw max of 40 or so amps at the output?
Mine also draws the full 46 amps that my supply will deliver, not good, the finals wouldn't last long that way.on a 70 amp power supply..(Astron) this radio does 315 watts SSB and draws 55 amps..go figure.. it should what draw max of 40 or so amps at the output?
