Custom Amplifier
heres a box i built and that i have for sale totally smokes wizards box check out the description on ebay under user name jeannem2987
better parts built better and for less money plasma therm ham 10 meter amplifier eimac 3cx3000a7 - eBay (item 140392736475 end time Apr-19-10 13:02:56 PDT)
6.6 kva plate supply
50 amp vac relay for output switching
vac relay for input switching
rotron centrimax 550 cfm blower big enough to cool a 15000 tube
real tube socket
eimac tube
pi-l input with a vacuum capacitor no air variable to possibly arc out
60 amp vacuum variable for the plate and load tuners wheich are big enough for a 15000 if wanted to upgade some day
interlocks on every door and panel
soft start on plate supply
working hv and current meter
has a foward and reflect meter but not hooked up has the line section just arent hooked up
Input adjust and keyer plug on front panel
Biased to class ab so can be used on ssb
Tube fully cutoff in receive
Chimney that vents hot exaust out of the box can hook up a dryer hose to vent hot air out of house.
Unit is on wheels
6 amp diodes
can be upgraded down the road to a larger tube or 2 tubes
all for less then wizard.Built to take a woopin.
I can build multiband boxes but will cost alot more.
compare mine to his check out the pics i have on ebay
