Hey Mack, really is a nice big image you got here, helps us old guys see better. Can you tell me how far from the bottom end of the lower tube #2 did you place the aluminum bracket #1? Or, did this bracket come attached to the bottom tube #2 from the factory? The image I'm talking about can be seen in image #6 of the mounting instructions.
Very good work Henry. If you can get the correct measurements and are willing to do another model of the New Vector 4000 with the basket on top, then we'll have a bases point to start evaluating the Vector. Otherwise we'll be all over the place with different ideas, different styles and construction, and likely with different results.
