Cobra 148 Mic Wiring
Wire Weasel
Senior Moment
Dec 13, 2008
3,308
971
223
Have a 5 pin 148 GTL that came with no mic. I have the wiring for a Turner +3 and am going to put that on for test.
At CBTricks it gives this for stock mic:
1) Audio
2) Shield
3) RX
4) Sw Com
5) TX
Under the "4 - Sw Com" What the heck does that mean?
And if I have a plain jane 4 wire stock mic around...how would that wire up as regards Pin 4 ?
Thanks for any help!
1) Audio
2) Shield
3) RX
4) Sw Com
5) TX
I have the
I have the very same problem anyone put us out of our misery?:blink:
Hi guy,
See the other thread I started about this. It's right below this one. Sick Puppy gave some help. You can ask him more questions if you need.
1) Audio
2) Shield
3) RX
4) Sw Com
5) TX
Sw Com means switch common and that usually means the black wire. It is common to the turning off the receive and turning on the transmit as you key up the mic. It can also double for the shield that is connected to pin two.
So for your "plain Jane" four wire you do not have to use pin two. On some mics the shield is not common with the black or ground. :wink:
73 mechanic
Reactions: Smokinone
