- I first erected the SGM on the 2nd mast, replacing the IMAX, 18' from the P500.007, you're reporting to us that the SGM shows stronger signals than your modified P500? "WOW!!!" hearing that is amazing. What's different now compared to a while back when you first got your SGM?
It was evidently interacting with the P500 much more than did the IMAX.
This last test was done with all other masts / antennas down, and the base of the SGM was at 40' above ground, as was the base of the P500 before it, also with no other antennas up.
Using the analog meter on my Icom IC-751A, Phil went from 8dB over 9 to 13 over in the 40 minutes it took to erect the SGM in place of the P500. Phil's S-9 + 8db has been consistent on the P500 for months. He is 10 miles from me according to Google Earth.How are you getting db measurements?
Same scenario, except Phil is using a Pro3.How did your test stations report in db's?
So far just Phil's, but in the last day I have had comments wondering 'what I did', ...my signal "sounds strong", "conditions must be good"' and so on. And I've seen what I would have to average as about the expected 2-3dB receive gain in multiple directions and distances over the P500, the 5dB I saw on Phil is the only real 'changing nothing except the antenna' test I've done and that was just to satisfy myself that it is still performing decently, even with the smashed coax, [but now I want to know what one will do if it hasn't been crushed!]How many stations have you compared for your report?
All things were left identical on both ends, so yes.Were your comparison results from your P500 also at 120 watts?
You question the db difference between TX/RX, don't you think that the amp has something significant to add to your TX?
How would that add to your RX using an amp, turn on the pre-amp? What if you were running 10,000 watts? ?
There was never an amp in line, only the 120w iCOM IC-751a.
N/AWhy do you use an amp in such tests?
